I would like to know if anybody knows how much would cost to upgrade to VDJ PRO from Virtual Dj LE Lite.
Thanks!!!
Thanks!!!
Posted Fri 07 Dec 12 @ 9:22 am
An upgrade price can be found by entering the serial number of your current product on the following page:
https://virtualdj.com/buy/
Simply type in your LE serial number in the box labeled "Upgrade to VirtualDJ Pro Full" and click "continue" to see what your upgrade cost would be.
Posted Fri 07 Dec 12 @ 10:04 am
Well i dont have the software, im thinking on buying a controller that comes with the Virtual Dj LE lite.
Posted Fri 07 Dec 12 @ 6:51 pm
If you speak of LE Lite - i think you mean the DJ2Go ? Upgrade can be found on bottom of the buy page. Enter your serial to check :
Greets, Heiko
Greets, Heiko
Posted Fri 07 Dec 12 @ 6:55 pm
Does anyone know if I can give my discount to someone else? I got the RMX after upgrading to the rpo version, so I didn't use my discount code yet. It is already regestered to me though.
Posted Mon 10 Dec 12 @ 3:11 pm
If it's already registered to you then it's not transferrable I'm afraid.
Keith
Keith
Posted Mon 10 Dec 12 @ 3:42 pm
Well that blows!!!
Posted Mon 10 Dec 12 @ 7:16 pm
The discount is intended for the original purchaser of the hardware and is an incentive to encourage LE (Limited Edition) users to upgrade to the full software.
You cannot give the discount to somebody else, especially when they don't actually own the controller, so are not entitled to it.
Posted Wed 12 Dec 12 @ 8:03 am
Why don't you guys list how much it cost to upgrade the software?
When I'm searching for a controller to go the digital route, in my budget I include the software. I have to say that I like the VDJ Home Edition a lot, but the fact that I don't know how much the upgrade is going to cost steers me away from going VDJ. Just sayin..I'll probably end up going with VDJ (hence why I am on this forum)
Posted Wed 12 Dec 12 @ 8:24 pm
hi i was a little confused that to buy virtual dj pro full would cost me $299 but it says i could upgrade vdj basic to pro full for just $49 which in theary would only cost me around $130 how does this work? thanks
Posted Tue 05 Feb 13 @ 1:10 pm
The price is starting at $49 (39.44 €) *
(*): Price of the upgrade depends on the product you upgrade from.
To upgrade from VirtualDJ Basic to the full Pro is $200.
To upgrade from VirtualDJ LE that comes included with various hardware to the full Pro is usually between $150 and $249 depending on the product that you are upgrading from (More expensive generally means greater discount.)
To optionally crossgrade from full Numark Cue or VirtualVinyl software to full VirtualDJ Pro is $49.
Posted Tue 05 Feb 13 @ 1:22 pm
ok thanks for clearing that up as it doesnt fully explain
Posted Tue 05 Feb 13 @ 2:17 pm
Dude if you want to be a pro just get the Pro version of Virtual DJ and stopping playing gigs for free and them you can make some money!!!!!
Posted Wed 06 Feb 13 @ 5:06 pm
its the extras in the program that makes it worth it. I have taken djing to a level that is non stop and kills everyone else. Im using
it is a cheap set up but its my programing that makes it what it is... The one controler is for scratching the second is the second set of decks and the apc is the effects and sample mods. The best part is that we get to get free updates to the next version. I cant wait to see how im going to mod version 8. The pro version allows you to have unlimited things set up and custom sound cards. The effects are also incredible and the script is able to be writen and changed with ease.
Posted Fri 08 Feb 13 @ 12:21 am
