I thought once that the Comment field was used when doing a search. I re-installed old version (v7.1,v7.2 etc) and used Mediamonkey to test and put certain TEXT in the comment field and when I search that TEXT in VDJ, it's not showing.
**edit***
Tried editing the Field 1, Field 2 and Comment in VDJ, all 3 does not show when searched.
**edit***
Posted Fri 07 Dec 12 @ 8:07 am
Did you read the VDJ user guide?
See page 15.
See page 15.
Posted Fri 07 Dec 12 @ 8:49 am
thanks groove, I knew it that at one point, it worked. I did not even check that (magnify glass) that those fields were turned off.
Posted Fri 07 Dec 12 @ 9:22 am
