Hello.
Today I tested loops on numark n4 and when I press it (first loop in and then loop out), it jumps a track a bit back (therefore when I press loop out it starts a loop a little bit back). If I do loops on computer there is no problem - it start loop from where I press button. Does anyone have that problem? Am I doing something wrong? Thanks.
Best regards
Best regards
Posted Thu 06 Dec 12 @ 6:07 pm
I am a Numark N4 user, with Virtual DJ Pro Full Edition, I recently had to reset all of my configurations to the factory settings, and now i am unable to properly loop and change between effects using my controller.
If I try to Reloop it takes me right back to the very beginning of the song, and when i hold shift + FX Param 1/Fx Select, nothing happens. Prior to switching my settings, this worked every time.
Can anybody point me in the right direction to get these functions back to normal?
Much thanks.
Much thanks.
Posted Sat 30 Mar 13 @ 10:11 pm
