Hey guys,
I've just got 2 new cdj nexus players at my club and I'd like to set them up so I can use them as decks 1 and 2 and then use my existing numark dmc2 for 3 and 4. I've tried setting it up but the cdj asio sound card only shows channel 1 and 2. I can control each individual deck though. Also the sound when using the asio driver is terrible. It is better when using the non asio sound driver but I can only get the first cdj to get any sound.
Any ideas?
Any ideas?
Posted Tue 04 Dec 12 @ 5:43 pm
Don't know if the other two will work properly, but you could go to the advance sound config and route those two to the same sound card you are using for the first two that are working, you can not have two asio drivers working at the same time...
Good Luck
Good Luck
Posted Tue 04 Dec 12 @ 8:24 pm
only way i can see you running all thru midi is using an external sound card. You will have control of all features on the program but the sound will come out of the soundcard. Most likely you will need a powered USB hub also
Posted Wed 27 Feb 13 @ 12:46 pm
