I am new to using the samples and effects. How do I download them from VDJ and then use them with my denon DN-HC4500? thank you in advance
Posted Fri 16 Nov 12 @ 5:44 am
Download effects here. Use them however you wish.
https://virtualdj.com/addons/effects.html
Posted Sun 18 Nov 12 @ 1:26 am
After installing the effect on your computer
Here is How to select an effect with the controller command
1) Pressing the Memo
2) pressure on a button effect either 1, 2, or 3
3) turn the PARAMETERS >> Ent to find the effect of his choice,
4) Pressing the >> parameters or Ent button Memo.
Posted Sun 18 Nov 12 @ 2:11 am
this is gunsblazeen,and im trying to find out how can get more word samples that go in the sampler,i don't have pro just yet but I want to know first before I get it
Posted Tue 20 Nov 12 @ 3:40 pm
I don't believe you can until you upgrade to Pro......
Posted Tue 20 Nov 12 @ 3:59 pm
Thank you
Posted Wed 21 Nov 12 @ 5:09 pm
so in pro beatbreaker what all word samples do you have to play for instance in the free edition it has the siren and throw your hands up word samples ,so when I get pro will it a more variety of those kind of word samples ,that's what I want to know,because I be doing rap and I got songs I put together and I want to mix them together like how djs do it but im low budget ,so I have to improvise by doing it myself, when I came across virtual dj I was like this is what iv been looking for but I need more word samples to play in between my mixes when I bring each song in, so that's why im asking about the variety of word samples for the sampler
Posted Wed 21 Nov 12 @ 8:14 pm
There are a huge number of samples available right here under the downloads section (the preview function doesn't work though, so you have to download and listen).
There are also many more on web sites around the internet. Some are free, and some are sold as "sample packs" or "loop packs".
Some will be aimed at hardware samplers such as the Akai MPC range, but they are just WAV files, you can use them in VDJ too.
Posted Thu 22 Nov 12 @ 5:38 am
im trying to figure out how to download music for VDJ HELP!!!!!
Posted Fri 23 Nov 12 @ 4:29 pm
Go to Itunes, enter credit card info, browse till you find something you like then charge it to your card, download it and play in VDJ.............rinse & repeat.
Posted Fri 23 Nov 12 @ 4:32 pm
i have itunes i wont show up in my brower on VDJ
Posted Fri 23 Nov 12 @ 4:56 pm
What version are you using?
Posted Fri 23 Nov 12 @ 5:37 pm
alright thanks if I need anymore help ill hit back
Posted Sat 24 Nov 12 @ 4:50 pm
