I have recently purchased a vestax vci 380 and hooked it up to my dell xps l502x i5 4gb ram laptop running vdj pro 7.3 version and its natively supported which was geat until i started to use the effects, i would for example have say an effect on each deck and then a combination of effects and then maybe chuck in a filter then all of sudden vdj closes and back to my desktop which is kind of worrying.
The effects i have been using are flanger, flan jet, echo, reverb, beatgrid, brake, laser ray, flippin double, phaser now i have manged to repeat this sudden crash 3 times and its always when using multiple effects, never freezes always closes and back to desktop?
Any help would be great thanks
Posted Thu 15 Nov 12 @ 3:51 pm
Tell me which three effects, and I will try right now. I'm live in a club, but I have back up. Plus, I have really big ones. I also don't think I will crash. I will let you know, right away.
Posted Thu 15 Nov 12 @ 8:43 pm
Sorry, I could not find three effects that would sound good at the same time, only two. I did however try 5 on my backup machine with no problems.
Ok, tried Echo, Flanger, and Flanjet, no problems, on gig machine.
Posted Thu 15 Nov 12 @ 9:00 pm
could be any number of things....
your system might need some clean up or optimization.....
try ctrl/shift/esc......how many processes ??
how full is the C: ??
when was the last defrag ?
do you use Aero ?
in control panel what are your power options set to??
try removing the battery ....
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
try those free items and that may do the trick.....
and if not there is no downside when you optimize your rig .....
do you use Aero ?
Posted Fri 16 Nov 12 @ 8:17 am
