If it's happening to you during a loop, then yes, it has been fixed. If you are referring to some other issue then it's not one I'm personally aware of?
Posted Mon 12 Nov 12 @ 7:09 pm
djharryg wrote :
What will be the "new" system requirements for VDJ 8?
This will be unknown till 8 is finished and finally released as it is still a work in progress. This thread is dedicated to the 7.3 release and all discussions not pertaining to the release should be posted else where in the forums.
Posted Mon 12 Nov 12 @ 7:36 pm
Thanks Stephane & Team ;)
Posted Mon 12 Nov 12 @ 7:37 pm
Thanks a lot!
Posted Mon 12 Nov 12 @ 8:47 pm
thank you for the update
i won't be able to really try it out until tues and friday .....
will the new parametric eq be addressable in the mixer view.......
also ....just type in the numbers ? ...... wow ..... that is great and simple....
might require some adjustment to taste ......
but, i'm willing to take off the next 24 hours , and take one for the team........
Posted Mon 12 Nov 12 @ 9:32 pm
Greetings, a question, now works vdj 48000 Hz or 44100 Hz still?
Posted Mon 12 Nov 12 @ 9:52 pm
ok on upgrade centre
do i upgrade the vestax vci400 le
or scroll down and upgrade virtual dj pro
im a vestax vci400 user
Posted Mon 12 Nov 12 @ 10:42 pm
Thank you VDJ for fixing the loop bug!!! thank you!!!
Posted Mon 12 Nov 12 @ 11:06 pm
Come on Numark Approve the update....Gotta get this 49 dollars up so i can upgrade.....ahhh the torture...
Posted Mon 12 Nov 12 @ 11:26 pm
Scroll down and update the VirtualDJ PRO ;)
Posted Tue 13 Nov 12 @ 12:32 am
Your opening statement should be slapped in the face of all of those who keep bugging, bitching, and complaining about the release of VDJ8.....just saying, just saying.
Having released out of my system, thank you Virtual DJ for all of the improvements, and I know things can only get better, and that's why I continue to use VDJ.
Posted Tue 13 Nov 12 @ 1:08 am
any tips for a beginner?
Posted Tue 13 Nov 12 @ 2:06 am
Please have a read here: https://virtualdj.com/wiki/PDFManuals.html
This topic is specifically for the new software release.
Keith
Keith
Posted Tue 13 Nov 12 @ 2:36 am
thanks you ***** and vdj for updating vdj and ******.
Mod Edit.
Political comments will be moderated . Please read our Forum rules. https://virtualdj.com/wiki/Forum%20Rules.html
Mod Edit.
Posted Tue 13 Nov 12 @ 2:41 am
Thanks for the update.
What's the difference between the registry entry ZeroDb and the new headroom? I used to set the default ZeroDB value lower than the default value, resulting in better sound quality on my Denon 4500 and Maya Usb.
Best regards Ewout
Best regards Ewout
Posted Tue 13 Nov 12 @ 4:36 am
Thanks guys. I have downloaded today and will be using it all week.
Thanks again.
Thanks again.
Posted Tue 13 Nov 12 @ 8:09 am
Great improvement my question is on version 8 will there be a way to assign the karaoke to a single player and for it not to take over the player that is being used? At the moment I have to use a different program to run the karaoke from due to this problem
Posted Tue 13 Nov 12 @ 8:23 am
Awesome. Gave it a whirl on my desktop and sound is great. Can't wait to hook up to my system.
THANKS TEAM
THANKS TEAM
Posted Tue 13 Nov 12 @ 8:43 am
This version supports de Ddj sx from Pioneer? ;)
Thanks!!
Thanks!!
Posted Tue 13 Nov 12 @ 10:11 am
Posted Tue 13 Nov 12 @ 10:21 am
