What do you mean by "this"?
Are you asking about the WeGO or setting up a separate headphone output?
Which VDJ version do you consider "normal"?
Posted Sun 04 May 14 @ 6:28 pm
that what i meant,virtual dj PRO FULL
Posted Mon 05 May 14 @ 7:31 am
Yes the full VDJ Pro has native support for the WeGO, and the WeGO has separate master & headphone outputs.
Did you buy a second hand WeGO? A new one would be supplied with VDJ LE, which you could use to get a discount on upgrading to Pro.
Posted Mon 05 May 14 @ 7:41 am
i own a wego2 and is using windows 7 with virtual dj LE. I am trying to get sound out of my controller and my headphones as well. i have tried every single thing from installing firmware, downloading aiso drivers, setting up the sound options as posted in the forums, starting up in the particular sequence with wego then software. i tried everything but i still wont get sound out of the sound card.
please tell me if i have missed out on anything . plzzzz
i really have use for this controller
Posted Thu 08 Jan 15 @ 7:10 am
