i am using a maya44usb external sound card on virtual dj. i keep getting a clicking noise when i am playing a song it is a 64bit brand new computer. Can anyone tell me how i get rid of the noise. I have tried changing the latency, but the reminder told me to use the auto if i am not using a timecode.
I really need help i am using vdj version 7.2 (b412)
Posted Tue 06 Nov 12 @ 6:30 pm
only thing I can think of is the Windows default sounds are enabled. Check if it is disabled for ALL sounds and for all Soundcard you have installed.
Posted Tue 06 Nov 12 @ 8:53 pm
Since its a new computer you should start here..
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Posted Tue 06 Nov 12 @ 9:51 pm
