Hiya im looking to get a new laptop . and just dont no wot to go for can any one help ?
im looking to spend about the £600
and help would be geat
cheers Dave
cheers Dave
Posted Tue 30 Oct 12 @ 11:35 am
Get as much ram as your money will afford you, if you plan to do video mixing make sure you have a good video card as well.
I believe NVidia cards work better with VDJ than the Radeon cards from AMD. If I'm wrong on that I hope someone will correct me.
I like Dell. Dell has a nice refurbished selection that I've used in the past, same warranty and all with a lower price on the front end.
http://www.dell.com/us/dfh/p/laptops
I use a Dell Studio 1745 with 4GB of RAM and the intel onboard video card. Loaded with Win7 Home Premium 64Bit. Works like a champ.
HP & Acer make some good laptops as well.
Posted Tue 30 Oct 12 @ 12:57 pm
i can recommend Samsung Laptops...and TDBennet is right...ram and the VC are essential...check out for minimum i3 cpu...and all will be fine..
Posted Tue 30 Oct 12 @ 1:46 pm
