my wego keeps crashing i have a 2012 macbook pro and about 2 times an hour it crashes and i have to restart the controller for it to work again. help this cant happen in gigs and i donnt know what else to do.
Posted Sat 20 Jul 13 @ 3:25 pm
I guess you mean the software is crashing. The WeGO can't crash - it's hardware.
Also you'll need to give a lot more info than just "it crashes".....
What version of VDJ are you running? What are you doing when it crashes? In what way does it crash? Is there any error message? Is there anything else connected to the computer besides the WeGO?
Posted Sat 20 Jul 13 @ 3:34 pm
Make sure that you have the latest drivers and firmware installed from Pioneer: https://virtualdj.com/wiki/Common%20Device%20Drivers.html
Also, make sure that you have the latest VirtualDJ LE installed. Register your VirtualDJ LE serial number to your account and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
Posted Sun 21 Jul 13 @ 11:47 am
i just get ddj wego and i get a problema with the pitch .when i mix , the first player get the pitch bloked and i can't control the speed anymore i have to go on the second deck to move the pitch and regulate the speed again ???? how it's work ?? i need to have my pitch to regulate my speed all the time....thank's !!!
Posted Thu 19 Dec 13 @ 10:17 pm
This is most likely soft-takeover.
Please see our FAQ pages: https://virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
Posted Fri 20 Dec 13 @ 7:05 am
nope its pioneers funky design, you have to hit shift key then it lets you change pitch sync etc...
Posted Wed 26 Mar 14 @ 9:53 pm
Boa noite.... recententemente eu peguei uma controladora ddj-wego k.....comprei usada e venho sem o cd de instalação
o antigo dono falou q usava normalmente no vdj.....na segunda vez q eu conectei a controlado no meu notebook ela reconheceu o mapeamento
agora ela ñ reconhece mais e sempre da um erro de directx......já vi vários tutoriais tds mandão baixa a atualização no site do suporte
sempre quando eu baixo o arquivo q esta disponível no site do suporte ele vem em um formato q o meu windows ñ reconhece
pelo o q eu intendi o suporte esta para o mc e win-8 eu uso o win-7....usei hj o win-8 para baixa o arquivo tbm ñ deu serto....
Poderiam me ajuda e indicar onde eu poderia Baixar o suporte q permite ver qual a versão do meu ddj-wego e mapeamento ?
Obrigado....
Obrigado....
Posted Wed 25 Feb 15 @ 4:00 pm
Por favor, poste novamente em Inglês ou usar o fórum para o seu idioma .
https://virtualdj.com/forums/11/Portuguese_Forum.html
Please post again in English or use the forum for your language.
Posted Wed 25 Feb 15 @ 4:47 pm
