I hope someone can help,
I upgraded my VDJ 7.0 Pro to 7.2 Pro and when I connect my hercules RMX contoller, the deck A Volume control slider moves rapidly up and down. It doesn't appear to effect the volume output but I need to hook up my main speakers to ckeck for certain. Anyone know how to fix this?
Thanks
Thanks
Posted Sun 14 Oct 12 @ 3:41 pm
update the controler driver...
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
Posted Sun 14 Oct 12 @ 11:58 pm
I already did...still not fixed... I am wondering if it is the controller
Posted Mon 15 Oct 12 @ 12:52 pm
As mentionned in another post, test the console outside of VDJ using the following procedure:
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
Posted Tue 16 Oct 12 @ 9:04 am
Turns out it is the console and not software or driver related.... Thanks for the help given
Posted Tue 16 Oct 12 @ 12:37 pm
Try spraying some contact cleaner in the fader, the crossfader on my djc.4 at a point was drifting left when moved 100% right and the contact cleaner fixed it. Worth a try anyway before giving up;^]
Posted Fri 19 Oct 12 @ 12:06 am
