Hello to the community. I recently had a problem with my MK4 DJConsole from hercules. When i opened VDJ, I couldn“t even play 1 song because the pc (or the console) crashed and nothing could be done. I tried like 15 times more changing the mode to ASIO on the MK4 control pannel and it still got crashed. Any help??
PS: My pc is a samsung netbook
CPU: Intel Atom at 1.7 GHz
Ram: 2GB
OS: Windows 7 Starter 32 bit
VirtualDJ: VDJ PRO full
Ram: 2GB
Posted Fri 12 Oct 12 @ 10:06 pm
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.)
Also, download and install the latest drivers and firmware for the MK4: https://virtualdj.com/wiki/MK4.html
NOTE: The MK4 will not currently work on USB 3.0 port. If you do not have 2.0 ports available, try using an external powered USB 2.0 hub.
Posted Sat 13 Oct 12 @ 3:33 pm
I had the same issue , suggest trying a different cable usb with the unit.. I had a extension usb that the unit wouldnt work with... change it out.. also update the herc driver to the newest one... then in the hercules set up select the asio as the setting in the herc setting in the lower right corner.
Posted Sun 14 Oct 12 @ 11:52 pm
