If any of you are familiar with the automation tools in Fruity Loops, this is for you.
I was wondering if I can prepare my set using the playlist and automate my knobs, faders, and effects.
I'm sure that this is possible and if anyone knows how to get this to work. I would really appreciate a tutorial.
Yes, if you think that I am cheating, you might be right. And then again, you might be wrong.
My dj equipment was stolen a while back and since then, I have given up mixing. I would really like to pick it up again and have no problem mapping my keyboard to mix. I would like this automation feature for recordings and when I decide to mix at a friend's party without having to spend all of my precious time mixing.
Posted Sat 06 Oct 12 @ 7:45 pm
Currently this is not possible. VirtualDj is a "real-time" mixing software.
You can manually adjust mix-in / mix-out points for your songs when they get automixed, but just about that.
The new version of VirtualDj (Version 8) will have a "timeline" feature that will let you do more on this subject, but right now as I said above it's not possible.
Posted Sat 06 Oct 12 @ 9:32 pm
I can't wait for VDJ8 to release .. is there a set date?
Posted Mon 08 Oct 12 @ 9:27 pm
No set date yet my friend. You should probably register your copy that way when it does come out its a free upgrade for you.....
Posted Mon 08 Oct 12 @ 9:35 pm
Ah, the art of mixing without mixing!
Posted Tue 09 Oct 12 @ 5:17 am
