Here is my setup cdj2000 and djm 400 also just got a traktor control x1. Been working fine until i just added the x1. Now when i try and sractch it moves up and down the track display view like for picking the next track on vdj. And i followed the guide for using x1 with vdj any help would be helpful
Posted Sat 06 Oct 12 @ 11:55 am
My question is can u run the cdj 2000s in hid mode and also have the traktor control x1 in midi mode. Also since i added the x1 i cant scratch on the 2000s when i do try all it does is like scroll up and down the tracks on vdj :(
Posted Sun 07 Oct 12 @ 11:38 am
It sounds like wheel_mode "browser" is enabled.
Have a look through the mappings for both the X1 and CDJ-2000 and see if there is a button that toggles this. Otherwise map a keyboard shortcut to wheel_mode "browser,jog" then use TAB to select each deck and press the shortcut to toggle the deck back to normal jogwheel mode.
It's also possible that the X1 mapper might set this mode at start-up for some reason. For further advice, please contact the author of the X1 mapper.
Posted Mon 08 Oct 12 @ 7:17 am
