What are good cameras for live-view mode, and are there any good cameras that can work over wifi?
I have used my Android phone (Galaxy S3) with the VDJ camera plugin, and while it works, the picture quality is poor. Also, the lag is quite annoying.
I know there are some other threads on this issue, but they are all fairly dated.
Posted Wed 03 Oct 12 @ 3:53 pm
you can use a USB web-cam too, but the problem i have is that in most venues there is very poor lighting and many cameras dont handle this very well.
Posted Wed 03 Oct 12 @ 4:45 pm
No matter what camera you use, if you bring it through Windows, there will be latency.
Went to a video mixer for that exact reason.
Web cams are a joke, but if you want to get as close to that as possible use a Sony D70
http://www.ebay.co.uk/itm/Sony-EVI-D70W-Web-Cam-OPEN-BOX-/300664080881?pt=PCA_Video_Conferencing_Webcams&hash=item4600f9c9f1
Posted Wed 03 Oct 12 @ 6:26 pm
I agree... and no zoom in on mine.
Posted Wed 03 Oct 12 @ 7:25 pm
I agree... and no zoom-in on mine too.
Posted Wed 03 Oct 12 @ 7:26 pm
Is go pro good?
Posted Wed 03 Oct 12 @ 7:58 pm
I use my Canon t3i DSLR and just feed it directly to the screen, somewhat expensive solution but you get full control of the exposure and the kit 18-55mm lens zooms in close enough for small - medium gigs, the 55-250mm lens works better for larger gigs.
http://www.qvc.com/Canon-EOS-Rebel-T3i-DSLR-18-MP-Camera-w2-Lenses,-Bag-&-8GB-SD-Card-Digital-Cameras-Cameras-Electronics.product.E222739.html?sc=E222739-Targeted&cm_sp=VIEWPOSITION-_-2-_-E222739&catentryImage=http://images-p.qvc.com/is/image/e/39/e222739.001?$uslarge$
or the newer t4i
http://www.qvc.com/Canon-EOS-Rebel-T4i-DSLR-18-MP-Camera-w2-Lenses,-Bag-&-8GB-SD-Card-Digital-Cameras-Cameras-Electronics.product.E223217.html?sc=E223217-Targeted&cm_sp=VIEWPOSITION-_-3-_-E223217&catentryImage=http://images-p.qvc.com/is/image/e/17/e223217.001?$uslarge$
or the newer t4i
Posted Wed 03 Oct 12 @ 8:06 pm
Timmy-
Can you explain more how you are using the T3i? Are you not using the VDJ camera plugin?
Will only the T3i and T4i work for live view. I have an original rebel, and a T2i. I can't seem to get either to work with VDJ.
Posted Thu 04 Oct 12 @ 3:31 pm
I'm not running it into VDJ at all, instead I go direct from the t3i's hdmi to my 42" tv. The t2i has a video mode, I recommend using an ac adapter for it so you don't have to worry about battery. The t3i and t2i video modes are stunning IMO, I use magic lantern features as well to get a good exposure faster;^]
Posted Thu 04 Oct 12 @ 4:10 pm
