on my computer if you go to control panel/numark usb audio/ the default (Auto Latency Settings) is = 256 Samples-7.3ms/32.7ms ? what is this setting and can i change it or should i change it and or is there an better setting to pick ?
Posted Sun 30 Sep 12 @ 10:52 am
Unless you're using a timecodes, it is best to stay on Auto latency.
Posted Sun 30 Sep 12 @ 6:20 pm
