Hi, I've been using my MK4 for 4 years now and it has been a great start, i recently purchased an amazing maschine mikro and was wondering if i can mix music with my mk4 while adding sounds an beats with my maschine at the same time out of the same speakers, can any1 help????
Posted Sat 29 Sep 12 @ 9:18 am
yes you can ;_) there is a programm out witch maks the sound of both VDJ and Maschine come out at one Output.
I don't know the name.....google helps you ;_)
greets
chrisXD
greets
chrisXD
Posted Sun 30 Sep 12 @ 11:59 am
google aint haelpin -.- if u knw can u possible let me knw asap! thx bro
Posted Sun 21 Oct 12 @ 8:32 am
Just use an external soundcard like the NI Audio2 and configure your maschine software with your ext. sc. route on out of the audio2 to one input of your mk4. Configure the inputs in the soundsetup in vdj. this should work....
Posted Tue 23 Oct 12 @ 8:03 am
but with the VDJ LE this way doesnt work.....he only would be able to mix on 1 deck....
Posted Wed 24 Oct 12 @ 1:28 pm
he has the 20 day trial to test it ( if he hasn“t already used it)...and if he want to use his line inputs someday he`ll better upgrade to the pro...this would make sense if he want to connect and use external hardware....
Posted Wed 24 Oct 12 @ 2:03 pm
I'm trying to upgrade to pro, thanks for the help! I'm probably going to get rid of the mk4 soon for a Kontrol s4 which would be a lot easier to sync traktor with maschine
Posted Sun 25 Nov 12 @ 9:43 am
