Hi Guys
I have a problem , I have win 7 64bit and serato SL1 . Everytime i connect my SL1 is says its an SL3 and i get an ASIO driver error.
I have tried all the fixes that have been posted but nothing is working .
Any Suggestions
Thanks
Any Suggestions
Thanks
Posted Wed 19 Sep 12 @ 2:38 pm
Have you tried reinstalling the drivers? Id reinstall serato with the box plugged in and see if that helps or click on the windows start button and find the serato folder in there. There should an option to reinstall the asio drivers again.
Posted Wed 19 Sep 12 @ 7:08 pm
I have tried that , still the same error :( any other ideas
Posted Thu 20 Sep 12 @ 3:25 am
Thank you for your help , the solution was as follows,
INSTALL SERATO FIRST
THEN INSTALL VDJ
THEN INSTALL VDJ
Posted Thu 20 Sep 12 @ 3:45 pm
