Hello,
I have mapped my cue_gain to work as my video cross-fader when the video and audio faders are not linked. Usually I CUE/PFL on a channel in my analog mixer so I can adjust the volume on my headphones there. When I practice or chill out at a friends I use the headphone jack on the front of the Mixtrack. I have remapped my EQ knobs to work other functions like the filter and key, when the shift function is active. I would like the CUE_MIX to adjust the headphone volume when the shift is active. I think my problem is that there is a shift button for either deck, and I need to work with a global variable, but I am unable to get the syntax correct.
Here are the action strings I have tried so far.
Can anyone guide me with the correct syntax please?
Max
var "$shift" ? headphone_volume : headphone_mix
var "shift" ? headphone_volume : headphone_mix
Max
Posted Wed 12 Sep 12 @ 9:48 pm
this should work as long as you haven't changed the shift variables name...
make sure you have the correct spelling and no duplicate controls in the mapper. You can reorder the list my name to make it easier to spot any duplicates.
Posted Wed 12 Sep 12 @ 10:48 pm
You can try setting your SHIFT button as ..
set "shift" 1 while_pressed & set "$shift" 1 while_pressed
and use the global $shift for your headphone actions.
Posted Wed 12 Sep 12 @ 11:07 pm
I thought that at first when I tried it before, but as i thought, it needing to set the global along with the local. Modifying djdads syntax with toggle allowed me to get the results I wanted. I wanted to keep the toggle option because I do other things with the shift active.
The following code is what worked for me.
Key: SHIFT
toggle "shift" & toggle "$shift"
Key: CUE_MIX
var "$shift" ? headphone_volume & booth_volume : headphone_mix
Thanks guys!
Max
Posted Wed 12 Sep 12 @ 11:28 pm
