Hello
is there any difference between skins for VDJ v6 and v7?
I got a laptop that runs best in 1366/768, and I can't find a default skin for v7 in this resolution. Maximize is not really pretty, and the skin resizer tool gave me a pretty bad result too (maybe I just don't know how to use it properly)
For version 6 this one exists:
https://virtualdj.com/addons/11435/Default_Skin_WXGA_1366.html
Is there any difference between the skins for these two versions?
Can I use the v6 skin without missing out on anything?
Best regards
Klaus
Best regards
Klaus
Posted Mon 10 Sep 12 @ 9:47 am
klausmogensen wrote :
Hello
Best regards
Klaus
Best regards
Klaus
My new laptop is also 1366x768
I was able to use the resize tool for both the 2 deck and 4 deck skin and it looks fine. What were the bad results that you had?
Posted Mon 10 Sep 12 @ 9:53 am
It was very gritty and in som places the font was close to unreadable
I would appriciate it if you would share yours :)
/Klaus
/Klaus
Posted Mon 10 Sep 12 @ 1:16 pm
Quote :
DO NOT simply resize or re-color something that has already been done by someone else. If you have receive the approval of such a change from the original creator then you must do the following before it will be approved.
Create a thread for your skin and get the original skin creator the opportunity to publicly agree to your modification for submission.
Provide the link to the above thread in the Description field during submission.
If a skin is found to be in violation of this then it will be Blocked from submission.
Per the rules I can't just submit the skin. I will be happy to tell you the steps that I did.
First I unzipped the skin and picked the 1440x900, since it was larger then the skin I wanted.
The first resize was to 1366x835 (not sure about the 835 being exact), leave the scale box checked.
Then I resized the 1366x835 to 1366x768. Un-check the scale box and enter the correct size. Check the browser resize box in the resizing menu.
This should yield a good skin.
Posted Mon 10 Sep 12 @ 8:28 pm
