Glad I'm not the only one enjoying the awesomeness of the djc.4!!! I'm finally getting used to the effects section on the right deck, sooooo much that can be done with so little effort, and the ASIO drivers are way better than the Herc RMX. I've done a few gigs with mine as well, running into ground loop isolator > sonic maximizer > ART 341 eq > xenx 1202 > Mackie Thump 15's, had the party jumping!!! Someone said, DJ Blaze I think it was on youtube, said the Herc RMX2 was about the same size as the djc.4, so maybe that could be a jumping point to finding a case, just make sure it's from somewhere with a return policy to be safe;^]
Posted Wed 31 Oct 12 @ 6:41 pm
' setting Asio latency and default scratch latency with the registry tool' - Can you explain what this means? when I DJ with this, occasionally I will get some static noise from the sound card which hasn't happened with other cheap USB sound cards I've used. Have I perhaps not set my latency properly?
Any help is much appreciated!
Posted Sat 28 Dec 13 @ 11:29 am
