is there a plugin or something when you play a Karaoke file the background is always diff or look live??
Posted Sun 02 Sep 12 @ 7:56 pm
Yes, it's possible with Essential Media plugin. You should make a two instances of that plugin. First plugin should be used for loading cdg+mp3 files on the screen and the background will be transparent. The second one will allow you to load any video or flash background. Loading cdg+mp3 files over the VDJ decks will not give you the transparent background. There was a thread about it a while ago, but I don't know does it exist any more. Hope this will help you...
Posted Tue 04 Sep 12 @ 1:35 am
thank you
Posted Tue 04 Sep 12 @ 8:17 pm
Hola amigo si me podrias mandar el plugin de karaoke ,porque nunca lo había usado y me he dado cuenta que que no lo tengo ,he tratado de buscarlo en el área de efectos y no lo veo te lo agradecería si me lo pasas porfa mi email esta en mi perfil. Gracias!!!
Posted Tue 04 Sep 12 @ 11:13 pm
I've had good results using the Sonique and other visuals faded in with the karaoke. play around with multiple decks, transparency settings, and such..
Posted Wed 05 Sep 12 @ 3:23 am
You may have better luck posting in the Spanish forum. but, to answere your question. The karaoke plugin is in the effects tab, under visual effects. it comes pre loaded with VDJ. If you can't find it there, you may have to reinstall as it is not in the effects downloads.
Posted Wed 05 Sep 12 @ 3:27 am
The initial poster is asking for a background to Karaoke files, using soniques will only give you an overlay effect and covers the on screen words giving to much of a distraction to the singer, no matter how much transparency you use.
Posted Wed 05 Sep 12 @ 4:21 am
Good idea, thanks!
Posted Wed 05 Sep 12 @ 2:59 pm
I forgot to say there are two ways to get karaoke transparent in VDJ. The first one is with Essential Media plugin and mp3+g files (described up there):
See example: http://youtu.be/20ldHkMmICo
The second way is with Firetext plugin and karaoke files in video format. Convert your mp3+g files to video format and load it into the VDJ screen over Firetext plugin. There are options inside the plugin to choose the colour of the background to be transparent.
See example: http://youtu.be/44JGWjS21DY
I've already described it all, just find that thread. Cheers...
Posted Wed 05 Sep 12 @ 5:13 pm
