how do i set all this up to play records (not time code)
i have the 1210s connected to the 1-2 and 3-4 inputs but its not working as normal ?
Posted Sun 26 Aug 12 @ 11:38 am
Its pretty simple actually.
You buy Virtual DJ Pro 7 and then ask the same question again.
Posted Sun 26 Aug 12 @ 12:41 pm
That's not the way it works round here. Just because someone asks a question about wiring the RMX is no reason to ask them to buy a VirtualDJ Pro licence.
We are a community and help newcomers to the forum the same as licenced users.
Just plug your decks in to inputs 1/2 & inputs 3/4 and make sure the switch is set to phono instead of line.
Keith
Keith
Posted Sun 26 Aug 12 @ 1:33 pm
i have a rmx and a turntable in input 1 i can play the timecode fine but when i put on a record the sound is so low, i up the gain and no luck still way to low of sound. Ive looked through forms but i have not found any help in this.
Posted Sun 26 Aug 12 @ 11:39 pm
If you are looking to use Traktor with the RMX, then it would be best to ask your question in their support forums.
These are the VirtualDJ forums for support with VirtualDJ software.
In VirtualDJ Console Edition, you can play analogue records by plugging them into the inputs on the back, making sure that they are set to phono and then press the SOURCE button to choose the external input.
Posted Mon 27 Aug 12 @ 10:26 am
