Hi,
Is it possible to use one pc with Virtual dj installed on, to control and play the music on second pc?
Tnx in advance
Ash
Tnx in advance
Ash
Posted Sat 25 Aug 12 @ 4:21 pm
ibuski77 wrote :
Hi,
Tnx in advance
Ash
Tnx in advance
Ash
You could do it with Remote Desktop or a VNC program, but don't expect any real time performance.
Posted Sat 25 Aug 12 @ 5:02 pm
one word....laaaaaaaaaaaag...
You'd be better off using the PC with virtual DJ and remotely accessing the music.
Posted Sat 25 Aug 12 @ 7:36 pm
Thank you.
I ment
I have an HTPC with all the music stored on, connected to my receiver.
And other pc on the network with Virual DJ installed on, and wonder if it possible to only to play the music on remote pc, without streaming.
Regards,
Ash.
I ment
Regards,
Ash.
Posted Sat 25 Aug 12 @ 10:46 pm
ibuski77 wrote :
Thank you.
I ment
Regards,
Ash.
I ment
Regards,
Ash.
Okay...maybe I'm not reading this clearly, but lemme try to at least clarify it for my own brain:
PC-A has the music...PC-B has Virtual DJ. Are you trying to use vDJ on PC-B with the music stored on PC-A to play and "broadcast" from PC-B? Or are you trying to control and play music using PC-B but to output your sound/etc. to PC-A?
If you're simply wanting to use the music from PC-A to mix on PC-B, then as long as it's networked you should be able to access it as if it were on PC-B's computer. I think it'll load temporarily into the cache for PC-B so there won't be streaming problems.
However, if you want to play and mix music to broadcast out of PC-A through vDJ on PC-B...I dunno...
Posted Sun 26 Aug 12 @ 9:24 pm
Thank you for yours advice.
I would like to mention, that the support and the kindness on this board, is one of the best, ever met.
(regard my question i had switch to Subsonic, that design for networking)
Thank you veryy much!!!!
Posted Mon 27 Aug 12 @ 1:36 am
