Hi Guys! How are you? I have a doubt, there will be some kind person who can help me?
Well, is this. I can connect my turntable (AMERICAN AUDIO TTD 2400 USB) directly to the computer and play with them with the software Virtual Pro Full 7j D?
Also I have a mixer (BEHRINGER DJX750) but it has no USB connection.
Well that's all friends!
Thanks to all. Regards from Spain
Posted Fri 24 Aug 12 @ 11:55 pm
generally the soundcards in decks like yours are made only for recording vinyl to mp3, they are not made to control timecode in dj software as they do not have low enough latency. If you want timecodes you should invest in a better soundcard. I use an NI Audio 8 and recommend any of their "Audio" series soundcards as they sound great. If your on a budget another alternative is a Maya-44 or torq connectiv.
Posted Sat 25 Aug 12 @ 3:24 am
I gave nearly the same answer on facebook ;-)
Posted Sat 25 Aug 12 @ 3:29 am
