Hi when i try to install my copy of VDJ i get the error below.
"the applications has failed because its side by side configuration is incorrect"
Ive tried installing as a different user, as admin in compatibility mode dont know what else to do now.
Anybody have any clues ???
Posted Fri 17 Aug 12 @ 7:36 pm
P.s i have the free home copy.
Posted Fri 17 Aug 12 @ 7:37 pm
Begin Activation Context Generation.
Input Parameter:
Flags = 0
ProcessorArchitecture = Wow32
CultureFallBacks = en-US;en
ManifestPath = C:\Users\Dean\Downloads\install_virtualdj_home_v7.0.5.exe
AssemblyDirectory = C:\Users\Dean\Downloads\
Application Config File =
INFO: Parsing Manifest File C:\Users\Dean\Downloads\install_virtualdj_home_v7.0.5.exe.
INFO: Manifest Definition Identity is (null).
ERROR: Line 0: XML Syntax error.
ERROR: Activation Context generation failed.
End Activation Context Generation.
Input Parameter:
Flags = 0
Posted Fri 17 Aug 12 @ 9:06 pm
Hmm...sorry I've never seen or heard of that error. How about you start by giving us you're computer specs. Then maybe an experienced user might have an idea.
Posted Fri 17 Aug 12 @ 11:41 pm
Use Google!
If you search for that error message, you'll find Microsoft posts which tell you how to resolve it.
Posted Mon 20 Aug 12 @ 5:38 am
