Looking for some thoughts ideas on this product.
http://www.amazon.com/Maxell-AirStash-Expandable-Capacity-Wireless/dp/B006473T92/ref=sr_1_1?ie=UTF8&qid=1343024101&sr=8-1&keywords=airstash+for+ipad
Currently for my mobile gigs I use my ipad 3 for outside ceremonies and cocktail hours in separate rooms where I would need two systems, it works great. I use DJay from Algorithm which I love. Obviously the IPad is extremely limited with space (64gb). My future plan is to purchase the iDJ PRO from Numark and use it as a backup system altogether.
Lets hear the good and the bad...
Posted Sun 05 Aug 12 @ 3:27 pm
well is it a wireless harddrive? imo anything wireless I wont touch when it comes to DJ'ing for simple reasons, what if the connection breaks. I would recomend something with USB/Firewire w/e
Posted Sun 05 Aug 12 @ 5:31 pm
its a bluetooth connection
Posted Sun 05 Aug 12 @ 7:25 pm
same goes with bluetooth, you want what can transfer info the fastest. Might work but think something with wire is better to be
on the safe side.
EDIT: As far as I know, you play a track from the harddrive, and connection breaks, track disapears
on the safe side.
Posted Sun 05 Aug 12 @ 7:29 pm
You gotta be kidding me. I bought one of these last week for $89.00 with free shipping. You want to spend all that money for 16g, just because it's blue tooth? I'm sorry, as Spock would say, it is not logical.
Posted Sun 05 Aug 12 @ 10:01 pm
I do. I need to expand the availability of my collection to the iPad. Is 64 enough to cover the basics, probably, but i like to be outside the box.
Posted Sun 05 Aug 12 @ 10:44 pm
