My BPMs seems to fluctuate +/- .5 when I am not at 0 pitch.
Been looking in Wiki and also searching the net for this but I can't seem to find a solution. I found this video on youtube, this guy seem to be having the same problem as I am.
http://www.youtube.com/watch?v=Rll54LJhpgA
The funny thing is, I also have Traktor and do not have this problem on Traktor.
Can someone please help me out???
Posted Mon 30 Jul 12 @ 10:19 am
Please see our FAQ pages (Timecode section):
https://virtualdj.com/wiki/Timecode%20Vinyl%20Wow%20And%20Flutter.html
Posted Mon 30 Jul 12 @ 10:36 am
Hmmm...I really must figure out a way to search Wiki better for some reason I did not come up with that. Thanks..
Another question: is this inherent with the VDJ engine? Cause I can't seem to replicate this with Traktor or Serato SL.
Posted Mon 30 Jul 12 @ 11:02 am
That's because your turntables aren't turning at a consistent speed, they'll never be perfect and mine do the same thing with Traktor and Serato. It's not just VDJ.
Posted Mon 30 Jul 12 @ 11:11 am
In VirtualDJ you can adjust it with the pitch sensibility option. This allows you to visually smooth out the fluctuations and make it more or less sensitive to them.
Traktor and Serato probably already do this by default (And may not allow you to change it) - The fluctuations will still be there of course - This is normal behaviour for using traditional vinyl decks which never run at a constant speed.
Ah that makes sense since Serato SL is built for timecodes.
Cool Thx, I will play around with the pitch sensitivity.
Posted Mon 30 Jul 12 @ 11:37 am
