Please do not post the same/similar message or question more than once.
You have already asked this question in the following topic: http://www.virtualdj.com/forums/181196/MAC_Version_Technical_Support/Macbook_Air_i5_2013_-_Laggy___Slow_.html
Posted Sun 08 Sep 13 @ 10:48 am
I think if you resize the virtual dj as i am playing around seems ok just not full size
Posted Wed 11 Sep 13 @ 6:03 am
Depending on your graphics card's performance and capabilities, you may get issues if you resize or maximise the skin because it must do this in real time on the fly. Please see http://www.virtualdj.com/wiki/Performance%20Issues.html
For best performance as well as best quality display, you should always use the skin at its correct native size. If it's not big enough, then you can download custom skins from http://www.virtualdj.com/addons/skins.html
Posted Wed 11 Sep 13 @ 7:30 am
Is the Denon MC6000 Compatible With Mountain Lion OS
Posted Tue 29 Oct 13 @ 9:49 am
Yes!
Posted Tue 29 Oct 13 @ 10:22 am
I have Virtual Dj with an Hercules Dj control mp3 e2. It´s been always working fine.
I had to erase everything from my mac and start again with a OS X Version 10.9.
Using the cd that came with the product I can instal virtual dj but I can´t open the drivers package for the controller.
I´ve been trying to download them from this website:http://www.virtualdj.com/wiki/Common_Device_Drivers.html but I can´t open the link.
Do you know what can I do?
Posted Sun 17 Nov 13 @ 1:57 pm
Please use the Hercules link :-)
http://ts.hercules.com/es/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=1
Posted Tue 19 Nov 13 @ 2:56 pm
