then you will probably love the Gold Edition too :)
Hercules RMX2 GOLD Edition
Download Link : http://www.virtualdj.com/addons/16854/Hercules_RMX2_GOLD.html
Posted Wed 23 Jul 14 @ 1:48 pm
Hey Dad!
Can you please tell me, how to map the "browser zoom mode" (fullscreen browser) in the default mapping?
kind regards
PS: Sorry for my bad English!
kind regards
Posted Wed 23 Jul 14 @ 2:03 pm
Ahh yes forgot about that.
You can use ...
toggle '$browsersize'
Personally i would use the VINYL button for such an action.
You can use ...
Posted Wed 23 Jul 14 @ 2:05 pm
Many thanks, Dad!
Posted Wed 23 Jul 14 @ 2:07 pm
any chance you doing one with the hercules dj air. not air plus just air. the rmx2 is awsome
Posted Thu 24 Jul 14 @ 8:29 am
Hi Dj Dad, thanks for this skin, that I can clearly read also in my mcbook air 11!!! I would like to know where is the command to change keys of one deck. I tried to assign it on the custom button, but it changes keys on both decks!
Posted Thu 24 Jul 14 @ 11:32 am
@gabrifir
You can map it with "SHIFT_SEARCH+/-" of your default mapping for example. I did so.
SHIFT_SEARCH+ -> key_move +1
SHIFT_SEARCH- -> key_move -1
greets
greets
Posted Thu 24 Jul 14 @ 12:39 pm
If you use the custom buttons, you will need to add .. deck x before the action, or else it will apply on the selected deck.
E.g.
deck 1 key_move -1
deck 1 key_move +1
deck 2 key_move -1
deck 2 key_move +1
E.g.
deck 1 key_move -1
deck 1 key_move +1
deck 2 key_move -1
deck 2 key_move +1
Posted Thu 24 Jul 14 @ 12:55 pm
Perfect, now I have all need!! Thanks!
I didn't press the space between deck and its number: what a nerd!!
Posted Thu 24 Jul 14 @ 3:56 pm
OK for keys, now another question: when selected effect mode on the console rmx2 any key you are going to press, only the first effect works and all the four button are illuminated( Flanger as default)
Posted Thu 24 Jul 14 @ 4:13 pm
Make sure you run the latest build (last 3 digits should be .740 or higher) and the "factory default" mapping is selected from the Controllers tab.
The 4 PADs in Effects mode, control 4 individual effect slots. Use SHIFT+PAD to select the next effect for each slot.
Posted Thu 24 Jul 14 @ 7:48 pm
Factory default and now go right. Thanks
Posted Fri 25 Jul 14 @ 9:31 am
Hi Dad!
I made some modifications for personal use (marked "bold") in the black skin:
1. line 173-179 Bigger time
---time---
<textzone>
<pos x="1254" y="3" />
<size width="110" height="25"/>
<text font="Arial" size="30" align="center" weight="bold" color="#d1d3d4" format="%fullhour"/>
<text2 font="Arial" size="30" align="center" weight="bold" color="#d1d3d4" format="%hour12"/>
</textzone>
2. Corrected position of "remain" and "elapsed" for both decks (line 727 & 733 left deck, line 2024 & 2032)
<group name="othertexts" >
<textzone >
<pos x="+410" y="+8" />
<size width="48" height="14"/>
<up x="+0" y="+0"/>
<text font="arial" size="12" align="left" color="#9D9E9E" weight="bold" format="REMAIN" scroll="no"/>
</textzone>
<textzone >
<pos x="+410" y="+35" />
<group name="othertexts">
<textzone >
<up x="+0" y="+0"/>
</textzone>
<textzone >
maybe an idea for update 1.1??
Greets
PS: Edited with Notepad ++
---time---
<textzone>
</textzone>
<textzone >
<up x="+0" y="+0"/>
</textzone>
<textzone >
<textzone >
<up x="+0" y="+0"/>
</textzone>
<textzone >
Greets
Posted Sat 26 Jul 14 @ 6:56 am
Screenshot (changes marked red)
Posted Sat 26 Jul 14 @ 9:03 am
Another thing:
When I enter "loop" mode and pressing pad 2 for seting a loop out , this sign appears: <_>
Neither pad 3/pad 4 or the nob above pad 2 changes anything.
See screenshot below:
Sytemconfig:
Win7 (64bit)
VDJ8.0.0 built1897.742
Default mapping.
Sytemconfig:
Win7 (64bit)
Default mapping.
Posted Sat 26 Jul 14 @ 9:51 am
The <> indicates that this is not a seamless Loop. It will be, if you enable the Smart Loop.
Btw, we are going to change the default mapping actions for the Loop section (as per Hercules' request). So the 4 pads will be .. LoopIn, LoopOut, Loop, Reloop.
You can always, half/double the size of the loop using the PARAM encoder, so it makes no sense to have /2 and X2 on the pads and the Loop action is necessary to trigger the selected loop (without manually make it with In and Out)
We will let u know when this change will be applied.
Posted Sat 26 Jul 14 @ 10:23 am
Thank you, Dad
Posted Sat 26 Jul 14 @ 10:47 am
I really appreciate the Virtual DJ 8 versions of this skin! A big thank you!
Posted Mon 04 Aug 14 @ 11:52 pm
Yes. A realy great skin. No doubt. But with many smal bugs, waiting to be fixed. -;) ;-D
Posted Wed 06 Aug 14 @ 12:08 pm
i need help mapping the mode button, when I press the button, it doesn't move through loops, effects, samples, and hotcues, in the appropriate order. please help
Posted Fri 08 Aug 14 @ 9:22 pm
