Is the rane sl2 interface compatible with vdj pro? I'm sure someone has already asked this but I can't seem to find an answer. I want to make sure before I go out and buy it. I will be using timecoded vinyl and a numark mixer. I also have a windows vista computer with vdj pro already installed if that makes a difference.
Posted Thu 19 Jul 12 @ 12:33 pm
I use an SL3 so I'd imagine it should work, but since I don't own one I can't be 100%. I'd say take your laptop to the store, download the drivers and give it a go.
Posted Thu 19 Jul 12 @ 12:41 pm
It works, I got one. Ensure that the drivers from the disk are installed first though to get VDJ to recognize that it is in fact a SL2 and not SL3, or else it wont allow you to use it properly.
Posted Thu 19 Jul 12 @ 9:51 pm
Sweet. Thanks homie. SL2 here I come lol
Posted Thu 02 Aug 12 @ 12:55 pm
