Hi all,
I'm using an NS6 with a Macbook Pro and the 4 deck VDJ skin.
I've been using deck 1 and deck 2 for mixing and have been trying to throw in some samples on deck 3 or deck 4.
So my problem is, say a song is playing on deck 2 and I press the deck change button on the NS6 to change from deck 1 to deck 3 and load the sample on deck 3, bring the cross fader over and mix in the sample, all works as it should. But when I press the deck change button again to change from deck 3 back to deck 1 so I can mix in deck 1- it appears ok but when I press play for deck 1 deck 3 plays and if I switch it back to deck 3 and press play deck 1 plays. If I do it on deck 2 or deck 4 the same thing happens.
So it seems it reverses the decks once I've changed and played something on deck 3 or 4.
The other problem is, is that it only seems to do it sometimes. If I close down VDJ and the NS6 and start again it seems ok. Weird I know.
Could it maybe be that I normally have deck 4 assigned to the microphone and then when I want to use it for a sample and switch deck 4 back to PC mode??? (I've tried it a couple of times and can't get it to do it though, just seems to happen randomly)
I hope that makes sense and someone can shed some light on it for me.
Thanks in advance
Thanks in advance
Posted Sun 15 Jul 12 @ 4:38 am
Are you using the 4 deck skin 3-1-2-4?
If not you need to download and install that skin. I use the same setup and have no problems using this skin.
Posted Sun 15 Jul 12 @ 10:16 am
Hi pskeens, You're a legend. I didn't even think to check that.
I downloaded it and it seems that has fixed that problem.
I've just been playing around with it tonight. I was trying all 4 decks, and some of the effects and just mucking around with the NS6 and all it's features and all of a sudden VDJ closed down and an error message popped up saying VDJ closed unexpectantly. Then the MAC asked if I wanted to send an error report to apple etc .
I restarted the NS6 and VDJ and basically tried everything I just did again to try and make it happen again but no luck. Mmm, hope it doesn't happen at a gig.
Any ideas on this???
Cheers
Cheers
Posted Mon 16 Jul 12 @ 5:39 am
If you are running Lion there are some issues with any vst plugin effects. It's best to remove them. I had this problem and I think it that solved my problem.
Posted Mon 16 Jul 12 @ 9:41 am
Hi, yeah it's running Lion. I'll check tonight when I get home and see if there's any VST effects.
From memory it crashed when I tried out the reverb effect, it just made a weird stuttering noise then VDJ closed down. Maybe I'll definately delete that one...
Silly question, but does it tell you if they are VST effects?
Cheers
Cheers
Posted Mon 16 Jul 12 @ 1:26 pm
