Before when I used to turn on my mixtrack pro after the buttons light up sync would stay lit up, but now sync is not lighting up, but cue button is lighting up instead which is making me have to sync tracks manually (myself) I'm thinking that I switched the mixtrack pro in cue mode some how & took it out of sync mode which means the sync button is not really working for me, but when I press play sync would light up & cue does not then sync works after I press play, but when I press stop cue lights up again and sync does not does anybody know how I can switch back to sync mode instead of cue mode? this cue mode is making me sync tracks manually myself I need to get this out of cue mode and back working on sync mode as soon as possible can someone please help? I cant even call numark because they are not open for help until monday which makes no sense for me because club djs perform on weekends especially on a saturday night & numark is not open on weekends for help ugh wtf this is my first issue with the mixtack pro can someone please help me fix this issue??
Posted Sat 14 Jul 12 @ 10:31 am
Just re-download the mapper and replace the new one with the old one in the VDJ Folder which should be under "My Documents".....back to the original state. I would venture to guess that by accident a mapping got changed, so just dump the old mapper and replace with a fresh copy.....
****But I see that you are a "limited edition user" so downloading mappers you won't be able to do.....Hopefully someone else will comment on the forum with some advice for you. Sorry I couldn't be of much help.....
****In a pinch I would just use my keyboard and mouse. A bit uncomfortable, but it can be done. The only other quick fix I see is to upgrade to the Pro version of VDJ and then you are set forever with all of the mappers, skins, effects and support you will ever need.
Posted Sat 14 Jul 12 @ 10:55 am
