I connected my 2 x cdj2000 players to VDJ 7. They sound great but are running a little sloppy and loose. They are not as accurate when mixing and scratching as when I run the players with time codes and not directly connected to the USB ports.
Is this normal when connecting to VDJ and using the midi control?
Also and the bigger issue.....VDJ only did this when the cdj2000 were usb connected to VDJ using the midi.....the music videos are not matching with the actual songs....for example ....if I load "moves like jagger" music video...the actual song plays but a completely different music video is playing on the output window. (the video for "back in time"). I had to reload the video and unlink the played Flag for it to work. HOWEVER....when the cdj2000 are not connected via USB and I use the normal time codes, or my pioneer ddj-s1 or just play vdj with nothing connected, Everything plays perfectly with no issues at all. Mp3s and mp4 videos.
What could be causing VDJ to select its own music videos that don't match with the actual song? Can anyone offer a solution for this. Thanks for your help.
Posted Sat 14 Jul 12 @ 10:16 am
