Hi,
have just purchased Virtual DJ.
I have connencted it up to my CDJ MK3's via an American Audio Versaport sound card however I only have around 80% functionality and only in "relative" mode. The timecode config only works in relative mode will not work in absolute and that means i can't use many functions on the CDJ's such as loops or pitch control. When I flick to Absolute I lose all controls, it just doesn't work. In Relative mode the timecode only seems to work when i set the CDJ's to Vinyl too, flick them to CD and I lose the controls.
The timecode is set up as Virtual DJ CD.
Can you please tell me what I am doing wrong?
Thanks
Thanks
Posted Tue 10 Jul 12 @ 4:29 am
Have you read this page ? https://virtualdj.com/wiki/TimeCode%20Config.html
Also since you're saying that you have set up your timecode engine as Virtual DJ CD I'm assuming that you have downloaded and burned THIS file onto a CD: https://virtualdj.com/products/timecode/VDJTimeCode_pro.mp3
Posted Tue 10 Jul 12 @ 7:49 am
