Can it be done? Is there a setting that allows me to go without the cord in between me and my midi DJ controller?
Posted Mon 09 Jul 12 @ 8:59 pm
I've never done it myself but use the advanced config and just choose the Bluetooth under headphones and then choose whatever your soundcard is for your controller. Like I said I've never done it but I don't see Why it wouldn't work.
Let us know when you get it working
Huey
Huey
Posted Mon 09 Jul 12 @ 10:33 pm
It may work but I wouldn't imagine it would be something you would want to do. There would be a bit of latency issues with them. Most Bluetooth headphones have a limited Kbps that they can stream to the headsets. There are some apt-X latency Bluetooth headphones available (Sennheiser for one) but they are over the $300.00 mark. The apt-X codec has around 320Kbps at approx 1.9ms latency.
Posted Tue 10 Jul 12 @ 8:36 am
