I want to get the Numark Dj2go but i have a concern, i dont know what usb sound card to use. I will eighther use virtual dj le or virtual dj home. Im trying not to spend over $100 in all.(including dj2go)Any suggestions for what sound card.(using it to cue) My main output would be going to an amplifier.
Thank you in advance
Posted Sun 08 Jul 12 @ 4:48 pm
Buy this cable for 20 bucks and call it good, http://store.apple.com/us/product/TU448ZM/A
I got mine from Walmart for 15 bucks..........
Also register your copy of VDJ
Huey
Huey
Posted Sun 08 Jul 12 @ 6:40 pm
The problem with that workaround (it's not really a solution) is that he'll only get mono sound.
Most people these days prefer their music in stereo!
I'd suggest buying a pair of USB headphones, which can then be used to cue the songs (in stereo) whilst using the computer sound card for the main output.
Posted Sun 08 Jul 12 @ 7:26 pm
You so smart............(hope you heard that in STEREO)
Posted Sun 08 Jul 12 @ 8:54 pm
Please see our FAQ pages:
https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
NOTE: Only VirtualDJ LE (If included with it) and the full VirtualDJ Pro will work with the DJ2GO. Home FREE and other versions do not support using MIDI controllers (Except for 10 minutes at a time as a trial of the full Pro.)
Posted Mon 09 Jul 12 @ 3:14 am
