I looked on the forums but I had no luck. I want to to be able to set values on my high mids and lows. I want to set the values of my pioneer dim 3000. Example the lows on the dim 3000 are from -26 to +6. Also I am using a mac.
Posted Sat 07 Jul 12 @ 12:35 am
I'm not sure you can do that yet but from the little I saw in the video of version 8 this will be possible.
If it can be done I'm sure someone else will chime on how to do it........
Posted Sat 07 Jul 12 @ 1:25 am
Posted Sat 07 Jul 12 @ 1:26 am
Hi, because I wanted to customise the EQ, I use a VST eq effect instead of the built in one in VDJ. I've found one that I use at my gigs, but I'm not totally happy with it, so I won't post it here, but there are lots of free and paid ones around.
Posted Sat 07 Jul 12 @ 5:39 am
I use "minimal systems instruments - ultimate 3 band" is absolutely pristine and much better than any other dj softwares eq, and imho better than the djm600/3000 as it doesn't run hot and distort when you push it.
Posted Sat 07 Jul 12 @ 5:58 am
