Does anyone here have the filter mapped to a controller knob anywhere? (NS6)
This is one thing that I cannot figure out where to put it at. There is nothing to give up really but the filter would be most helpful on the hardware somewhere.
Posted Fri 06 Jul 12 @ 10:40 pm
Filter is mapped by default.
Dont have the unit, but browsing through the mapper, it should be activated by pushing the FX parametr knob and controlled then by that. The FX A button should also reset the filter to 50%
Dont know what skin you are using, but you should try with the default, as the above activation requires either the mixer or the scratch panels to be on.
Posted Fri 06 Jul 12 @ 11:00 pm
Thanks, I will give that a shot. I don't know why I never knew this.......
Posted Sat 07 Jul 12 @ 7:22 am
This might help you ...
https://virtualdj.com/addons/download/src/13230/NS6-VIRTUALDJ%20Manual%20-%20v1.0.pdf
Posted Sat 07 Jul 12 @ 12:37 pm
