Hi! I cannot scratch in my software right now because the jogwheels only give sound in the "Forward direction" of the track. I've tried checking all the settings and nothing seems to work! help please
Posted Wed 04 Jul 12 @ 4:36 am
Which version of VDJ are you using and are you also using a controller?
You may need to disable "smart scratch" on your skin.
Keith
Keith
Posted Wed 04 Jul 12 @ 5:04 am
I'm using the 7 pro with a Numark Mixtrack pro controller!!! I got a gig tomorrow as well and i need to be scratching!!
Posted Thu 05 Jul 12 @ 5:11 pm
Register your copy of vdj then download the registry tool and adjust your settings then scratch away....
Posted Thu 05 Jul 12 @ 5:29 pm
Thank you guys for the help, i did have smart scartch on and now i got it sorted, props for the help
Posted Fri 06 Jul 12 @ 4:46 am
