Forum: Old versions
Topic: Midibox 64 led problem.
Hy!
I built the MIDIBOX64 controller. More here: http://www.ucapps.de/
It works perfectly but there is one small problem. How do I refer to the leds in VDJ script? Example: The play button is blinking when song is loaded on deck. How do i follow this. What are the leds ID-s? Example the buttons IDs 0-25,0-30....
Can someone help me?
Thanks!
Posted Sat 23 Jun 12 @ 2:12 am
You will need to have vdj pro full to be able to use external controllers.
Then you need to make a mapper and definition file so vdj recognises your controller otherwise the leds wont work. both files are simple xml files so vdj can interpret the incoming and outgoing midi messages.
When you register you get access to the definer tool which makes definition files a breeze if you don't know what you are doing.
More information can be found in the wiki.
https://virtualdj.com/wiki/ControllerDefinitionMIDI.html
https://virtualdj.com/wiki/Controller_Definition.html
Hy!
I have pro version. The midi controller work. I can use with virtual dj button, potentiometer, encoder. I dont know what is the led note.
