Hi!
I usually use Serato when I play gigs, and i borrow it from a friend.
I got a gig in a couple of days and I cant borrow his serato, and I thought i could use VDJ.
I will be using a 3.5mm plug for the speakers, but my macbook only has one 3.5mm output. So how can I use my headphones when I mix? I have one of these: http://gadgetaccessorystore.co.uk/images/product_images/headphonesplitter_35_to_35_w.jpg, but when I use it the same sound goes through the headphones and the speakers.
Please help! :)
Please help! :)
Posted Mon 18 Jun 12 @ 2:15 pm
I guess you didn't bother searching the forum first, eh? This is THE most FAQ by beginners.
I guess you also didn't see the message above your post that says "Before posting.....read the FAQ".
Anyway, the answer lies here https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
Posted Mon 18 Jun 12 @ 3:05 pm
