Hi, I recently purchased 2x 1000 watt 3way Speakers and a 700 watt Amp and I connected it all in following:
Speakers ----> Amp ----> JBsystems DJ Kontrol 3 ---> Laptop ---> VitrualDJ
The Amp and Speakers are in perfect working order as I have run them from my hifi, but I am only getting minimal distorted sound when running from my laptop with VitrualDJ.
I have tried the room configuration with a microphone and no luck, no bass and poor sound.
Any help would be immensely appreciated as I have my nieces party coming up and I don't want to let her down.
Posted Fri 15 Jun 12 @ 12:38 pm
Hi
I'll ignore your using a 700 watt amp with 1000 watt speakers.......
It would help a lot if you provide some more info rather than just saying it's distorted.
How have you got things wired up? You should be setting VDJ to output audio to the DJ Kontrol 3, then running the DJ Kontrol 3 output to the amp. It's because you said you were "running from my laptop" that I'm thinking maybe you're not using the DJ Kontrol output.
And also what do you mean by "room configuration with a microphone"?
Posted Sat 16 Jun 12 @ 5:04 pm
I'm thinking he's using a home system amp, with its home speakers coz
Posted Fri 22 Jun 12 @ 9:11 am
