does somebody tell me where a can find that scratching stop sound sample? thanks
Posted Mon 04 Jun 12 @ 8:11 pm
Are you talking about back spin?
Posted Mon 04 Jun 12 @ 11:48 pm
the sound i mean is like when somebody like in a tv series says something bad and you hear that scratching noise and then silence
Posted Wed 13 Jun 12 @ 11:14 am
try effect: brake
Posted Wed 13 Jun 12 @ 11:29 am
you need to upgrade to pro for any of these suggestions but you could:
get a scratch sample load it into sampler 12 and map yourself a bleep button
you could map "dump" so you reverse the audio from where you are but keep progressing past the swear word.
eg. I'm a mother rehtom hustler
or you could download forward reverse if you want to play the swear word in reverse missy elliot style.
eg. I'm a mother gnikcuf hustler
you could use rollit, looproll, roll or beatmasher single to stutter the previous word, while progressing through the track. loop roll is probably the safest though as you can instantly stutter the sound you just heard, the others must first record the sample before repeating.
eg. I'm a mother mother hustler
eg 2. I'm a mother mu mu hustler
If your djing in places it could pose a problem like a "13 year old church group choir" or something random like that your better off editing the files in a daw or wave editor so you don't need to keep hitting the button on stuff dr dre/death row produces etc... "listening to doggystyle lol"
https://virtualdj.com/addons/effects.html
deck default volume 0% while_pressed & sampler 12 loop off & sampler 12 play
Posted Wed 13 Jun 12 @ 12:45 pm
Er, at what point did he say he wanted to edit out cuss words?!
There are plenty of tunes that have that classic "record stopping" sound.
If you mean the "record being jogged" sound, that's used in Trading Places.
Posted Wed 13 Jun 12 @ 2:30 pm
right about here ;-)
also unrelated but I just accidentally found out how to do multi quotes :-D win
Posted Wed 13 Jun 12 @ 3:15 pm
no, not triying to cover bad words, i did a google search and found the sound effect in a forum, its called record scratch damage. thanks anyway for the responses.
Posted Wed 13 Jun 12 @ 8:54 pm
