Forum: Old versions
Topic: PROBLEMS ON DISPLAYING ON CHINESE WORDS.
I'm using VDJ Home free and using the skin Mix Lab v3.1 . First few week it works well on chinese words (have a look on the first photo) . but started last week the problem comes. all the chinese words turn in to squares(second photo).
this is the photo that work: (first photo)
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/268849_158819827522587_100001837137432_379404_1622961_n.jpg
this is the problem:(second photo)
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/543650_339762996094935_100001837137432_855990_1792945024_n.jpg
can u teach me how to fix it for me as fast as possible. thanks
Posted Mon 28 May 12 @ 4:04 am
This depends on the skin that you are using and what fonts it uses.
Some Mac fonts don't support unicode characters for all languages.
MixLab 1.3 is an old skin designed for VirtualDJ v5.1. Try using the default VirtualDJ v7 skin. Also, make sure that you have the latest version of VirtualDJ Home FREE installed from https://virtualdj.com/products/homefree.html
can u teach me how to change the font:)?
