Hi guys, sorry to be a pain but I'm posting this here because nobody seems to use the Mac section of the forum.
I just got VirtualDJ Pro 7.0.4 I think, a friend gave me a new copy after he decided to use Traktor instead I think. Generous eh. I installed VDJ it on Macbook Pro lion 10.7.4
I've got it set on Advanced Output, a Firewire Alesis Multimix12 connected as the main mix out, and my headphones plugged into the 3.5mm jack in the laptop acting as the mix monitor.
I can mix successfully for a few minutes and simply put my headphones monitor signal goes all fuzzy or distorted. It's like the computer lets go of the on board driver that's running my headphones, the mixer output is unaffected but the headphones are unusable it's like theyre all distorted and dying.
Am i missing something where setup is concerned?
My macbook spec is core 2 duo 2.66ghz, 4gb ram osx 10.7.4
Cubase, reason, logic all run fine on here so why shouldnt virtualDJ?
Thanks
Thanks
Posted Mon 21 May 12 @ 4:43 pm
Your question have been already answered in the MAC FORUMS please do not post the same question in every forums.
Posted Tue 22 May 12 @ 1:10 am
Thanks but it wasn't helpful unfortunately it didn't solve the problem. I think the problem is in the software, everything else I use functions correctly. Thanks
Posted Tue 22 May 12 @ 6:34 am
Please do not post the same message more than once.
Continue all further discussion on this subject in your other topic:
https://virtualdj.com/forums/164571/MAC_Version_Technical_Support/Macbook_Pro_setup_advice__please_help__Headphones_not_working.html
[Duplicate topic locked]
Posted Tue 22 May 12 @ 1:10 pm
