Please could anyone give me some advice on the setup i need in virual dj to record audio using the hercules 4mx as the controller.
Posted Sun 20 May 12 @ 5:56 am
I've never tried recording through the controller and out from VDJ.
I use Line Out 2 to my 2nd computer's Line In. Then I use a free software (Audacity) to record the Line In audio.
Audacity: http://audacity.sourceforge.net/
Recording with Audacity: http://audacity.sourceforge.net/manual-1.2/tutorial_basics_4.html
Hope this helps.
Hope this helps.
Posted Wed 23 May 12 @ 8:05 pm
Correction to Above:
I use Line Out 1 (RCA) to play music through the amplifier.
I use Line Out 1 (1/4" to RCA -> 1/8") to my 2nd computer's Line In. Then I use a free software (Audacity) to record the Line In audio.
Hope this helps.
Also,
The Hercules 4-MX is a controller. What ever you do on the 4-MX is what happens in Virtual DJ. You should be able to go to "Record" in VDJ and record your live mixes from there. I tested last night and it worked OK for me.
Hope this helps.
Also,
Posted Thu 24 May 12 @ 9:00 am
