Forum: Old versions
Topic: Changed Stylus' - Problems :-(
Evening :-)
Started using VDJ at the start of the year and had a couple of issues >>> https://virtualdj.com/forums/158995/PC_Version_Technical_Support/New_User_-_Old_TT_s_-_Maya44_-_Searto_Vinyl_-_Help_.html
All was working fine, and today I have just fitted some new stylus' to my Trackmaster II shells. The stylus' I fitted was Stanton I-Tracks which are a compatible replacement (TMII needles are no longer available, V3 are available but quite expensive to replace both!).
I've found that since installing the new stylus' that the quality (when looking under the settings) jumps all over, from a single digit up to 100% but just all over!
Previously the quality was 80-100% but the needles I have had for 10years (with about 6years continued usage) so I figured they were due a change?! Lol.
I have no idea what's happened really, but quite frustrated. Surely the only experience I should have had should have been an enhanced signal?! Hmmmm ...
I'll post some screenshots tomorrow to help explain.
Posted Sat 12 May 12 @ 2:40 pm
Anyone :-)
