Hey guys, bought the hercules dj console rmx recently, having difficulties setting up my speaker issue. What speakers do you reccomend that arent crazy expensive, anywhere between 0-200$ i was thinking, but still loud and that i could use to play a parties and dances and etc. Any help would be appreciated, just need some help getting started, thanks for any help!
Posted Wed 09 May 12 @ 7:30 pm
That budget will be fine - if the "parties and dances" are in your bedroom. You could buy a small pair of computer speakers, or maybe even some tiny hifi speakers.
If you're looking for PA speakers that you can use to play to a crowd of people in a large room with a dancefloor, then you'll need to spend much more than $200 per pair.
Posted Thu 10 May 12 @ 6:07 am
I agree with groove. You don't necessarily have to spend more. But you get what you pay for. Always remember that in this type of business lol. I learned the hard way. If your looking for loud good quality speakers, its better to just save up for them. Itll help you in the long run.
Posted Thu 10 May 12 @ 11:21 pm
Yea... but what speakers should i get?
Posted Tue 29 May 12 @ 7:03 pm
